Old 08-10-2012, 07:05 PM
BanditCub BanditCub is offline
Thanks all!!
Ripper works pretty good for getting the driveway loose, it's compacted shale from when I built the house so it packs in really tight. When I was using just the rake i would have to make about 50 passes up and down it before it was even loose. Now a few passes with this and it's ready to rake. My driveway is about 1500ft long so this is a huge time saver. Thanks again!
Red '84 Cub Cadet 782
50" Deck, 54" Power Angle Blade, QA42 Blower, #4 Cart, #2 Cart, 400 Rear Tiller, IH Rear Grader Blade, IH Rear Rake, IH CI Weights, Rear Suitcase Bracket, Sleeve Hitch, Front Hyd.
Old 08-10-2012, 08:05 PM
IHinIN IHinIN is offline
Nice job on the ripper and blade.
Old 08-10-2012, 08:11 PM
sspencer sspencer is offline
That thing is too cool and would be perfect for some work I'm going to be doing this fall!, I'm going to have to build one.
Quick question, how did you cut the holes for the for the shanks? Were they torch cut?
Scott
Old 08-12-2012, 07:23 AM
Thanks guys!
Well, I got a quote from a guy who had a waterjet table to cut the holes, he told me about $100 bucks. So after some thinking I said well for a $100 bucks I'd rather do it myself and pocket the money. Long story short, I used a big drill bit (3/4") and then a 4.5" grinder (not much I can't do with a 4.5" grinder) and cut the slots. The problem was they were still to tight. In the end I ended up using a torch to stretch the slots just a little more.
If i had used a larger drill bit it would have gone much smoother and faster.
Old 08-12-2012, 08:10 AM
johncub7172's Avatar
Nice work! That IH backblade is cool. I bet that is handy too! Thanks for the time and pictures!
Old 08-12-2012, 08:54 AM
Sugarmaker's Avatar
BANDITCUB,
Lovin the ripper fab work! very nice construction! I would add a back blade like that to my collection any day of the week. I have not seen any around here.
Great job on both implements! Thanks for taking the time to post the shots.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 08-17-2012, 03:51 PM
Thanks all the compliments guys.
When I get the rake done I'll try and post up some pics of it as well. The tine replacement is going to take a while, they are no longer made, so having to use the A&I universal ones is going to take some time.
