Old 08-12-2012, 08:01 AM
There is a Spirol Pin on the Coupler that attaches to the Input Shaft. If that pin breaks, one will have NO hydro function.....BTDT.
SumBum's Avatar
SumBum SumBum is offline
Ah....I see, you are suppose to click on the image, and it takes you to a Photobucket Video.
Not having any luck viewing that video....I hear the audio but no video.
Oh.. I didn't look at the video either. Yep the shaft is definitely spinning in the video..
Old 08-12-2012, 08:39 AM
dieseldan123's Avatar
Ill have to go back and see the video, but if look at that image where the visible springs are, you will see that your Trunnion is about worn out, i.e. one of the two plates that contain the springs. It may not be a direct influence on your issue but it will help you acheive a drive out of your 1650
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 08-12-2012, 01:05 PM
all4jpn all4jpn is offline
Ok something to check on. Bedell, where is this pin you are referring to is there a good pump diagram somewhere so I can see things better (I'm a newb) it that pin broke, would the shaft in the rear of the hydro still spin as it does in the video?
Old 08-12-2012, 01:08 PM
Also where is the charge pump, how do I test it, and how do you prime the pump? Thanks
Old 08-12-2012, 01:35 PM
ajgross ajgross is offline
Inactive Member
Did you move the tractor while it was broke down? You can tow these things but you need to go slow and not for long distances. If you moved it and went too fast, you could have severely damaged the pump. It's the only surefire way to destroy one of these things. From what I'm seeing, it looks like the most likely culprit.
AJ
Old 08-12-2012, 02:37 PM
It was only pushed a total of about 40 slowly by hand and not all at once. When u say destroyed are you refering to the transaxle or the pump in regards to being towed?
Old 08-12-2012, 03:08 PM
It will be the pump. It will undo something to the degree of hydro lock causing the pump to fail.
Old 08-12-2012, 03:13 PM
Ok. So it seems the pump is shot. What is the noise that is being made when the lever is all the way up or down(see vid)
What model is the pump, are they rebuildable, and is there a manual?
Also what other cubs had the same pump. Thanks so much for the help
Old 08-12-2012, 03:52 PM
restore49 restore49 is offline
Would be rare the pump died from sitting - the relief valves are stuck not letting the pump build up to pressure or the filter has blocked the fluid return. Find both known good valves to try and replace filter Wix 51410
