Old 08-16-2012, 08:46 PM
jr315 jr315 is offline
correct!!!! do u think the mounts and lift bar will work also?
Old 08-16-2012, 08:56 PM
cub123's Avatar
cub123 cub123 is offline
I would say the lower bracket that bolts to the trans and the two lift straps will work. It should only be about a 15 minute job to swap these parts. If it was me I would just swap them and see how it works.
Old 08-16-2012, 09:00 PM
mrcubcadet's Avatar
I have never had an older style adapter in my hand, but I believe the holes are the same width apart on all Cub Cadet Brinly adapters.
-105___ Tiller
Old 08-17-2012, 08:54 AM
everything is a perfect match EXCEPT the lift bar , does any one have any pictures ?
Old 08-17-2012, 12:40 PM
Shaner Shaner is offline
if your talking about the 3point assembly...the Original 3pt and narrow frame 3pt are totally different. the brinly adapter will work on both original, narrow and wide frame, but the 3pt itself will only work on the tractor it was made for.
