Old 08-18-2012, 10:08 AM
Originally Posted by Flatbedford View Post
What size fuse should be used?
Steve,
I always use a 20A with a water-tight fuse holder, though a water-tight fuse holder really isn't necessary.
Old 08-18-2012, 10:23 AM
Steve,
You might as well not be using a fuse. I'm finding varying numbers for the current carrying capacity of 14ga wire, but all I've found so far claims it to be under 20A. The parts lookup specifies a 10A fuse for the lights circuit, which is more than sufficient for the current draw of the two 35W headlights.
Old 08-18-2012, 10:41 AM
10A fuse is the proper size of protection for lighting and 14GA wire. Anything higher can be a fire hazard.
The lighting circuit is considered optional on a 129 and the harness does not provide for it.
