Old 09-05-2012, 06:41 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Sounds like a good solution. There's not much room in there for much of anything else. While I'm a firm believer in oil and lubricants, aren't "oilite" or impregnated bronze bushings advertised as self lubricating? The oil wick would indicate these aren't .
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 09-05-2012, 07:58 AM
restore49 restore49 is offline
Pop out the original oilite bushing - mike the Od and shaft Od stop at a large hardware store and pick up a replacement. If you can not find or order one from MSC send me the measurements and I will turn one up for you. Saturate the felt with fresh TUBINE OIL and good to go for 20 years.
http://www.reidsupply.com/products/b...eeve-bearings/
Old 09-06-2012, 08:37 AM
save_old_iron's Avatar
save_old_iron save_old_iron is offline
Originally Posted by save_old_iron View Post
Maybe a small hole at the top of the welch plug and fill with oil thru a syringe and needle - then a dab of silicone to seal the hole ?
Never mind what I said there.
Now that I see the outside of the end cap bracket has another welch plug (much smaller) where I imagine an oil cup could be fitted. The casting from the smaller welch plug appears to lead down into the oil reservoir area, not directly to the side of the bushing as I first thought.
If you do not learn something new every day ... you are not paying attention !
