Old 11-04-2012, 10:15 AM
EricR's Avatar
EricR EricR is offline
inboardnut, you are right, those shift handles are to short. Here is the one PaulS is refering to that we went with.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 11-04-2012, 12:32 PM
PaulS's Avatar
PaulS PaulS is offline
Ok in that pic does anyone notice another modification which is clearly visible in the pic. Eric and I used a piece of threaded rod and a connecter and just bolted it on no modification to originality was needed. It was cheap too, less than $2.00.
Old 11-04-2012, 12:34 PM
inboardnut's Avatar
inboardnut inboardnut is offline
Cool! I tried to do a search and couldnt find anything on it.
Glad to see "Great minds think alike"!
Old 11-04-2012, 12:36 PM
inboardnut's Avatar
The custom upholstery job?
Old 11-04-2012, 05:29 PM
PaulS's Avatar
Nope that is just so my bottom feels good when speed mowing. There is something else.
Old 11-06-2012, 11:29 AM
123Pokey321 123Pokey321 is offline
[QUOTE=PaulS;157858]Ok in that pic does anyone notice another modification which is clearly visible in the pic.QUOTE]
Ag's? Wheel weights? Spiffy new-lookin floor board covers?
Old 11-06-2012, 09:47 PM
PaulS's Avatar
Yep Pokey hit it. Those are not new spiffy foot rests but I did clean them and then Painted the "Cub Cadet" in yellow. It may not last but I thought it makes it stand out.
Old 11-07-2012, 12:04 AM
NW Hick's Avatar
NW Hick NW Hick is offline
Default Fixin' the Shifter
The shifter on my 1641 looks a whole like yours, so in case it shares parts under the dash, here is my 2 cents:
I ws quie suprised when my shifter broke off in my hand one fine day when I was yarding logs. I was able to get home by shoving the broken part through the slot it used to go through and push the sheetmetal stub.
The shifter had been riveted with two rivits going through the spring steel/sheetmetal bracket (there are two springplates) and the potmetal shifter handle. The bottom half of the springplate is rivited to a flange on the horzontal shaft that connects into the rest of the brake/shifter linkage. Take out the battery and you can grind off and drill the rivits. You might get away with grinding the original part flat, redrill it and attach it with a pair of #10 machine screws and nuts but they will vibrate loose and you will find the shifter an inch too short, anyway. I built a forked-ended plate with round stock welded to it to take up the sideways thrust of the springplate as you move the shifter right & up for forward and left and down for reverse.
Knowing that parts don't just break for no reason, I pulled the cowl over the driveshaft and went through each connection in the linkage, cleaning away surface rust and greasing all moving parts. The result of this is that the tractor suddenly had twice as much power in reverse as it ever had since I bought the machine at 600 hours. The shifter no longer crept down from "6" to "4" when driving around. Everything just works better.
I like your new handle, but suggest that you go through your linkage and lubricate the joins because if yours binds, the longer handle will make the pot metal bottom break off easier.
Steve
Cub 1641 - Accepted to settle a $400 debt
I got all of the original paperwork with my Cub! The buyer traded in something in for a $4999 credit, and used it to buy the 1641, a roller, wheel weights, box blade, mower deck & bagger, Ripper, Seeder, two sets of tires, and a trailer.
I added DOT headlights, tailights & flashers, a beacon, 3000 lbs winch, bumper & brushguard, 18 inch front tires, dump box, HD Exhaust, & scabbard.
Old 11-07-2012, 11:30 AM
WooHoo! It's like winning the lottery!
Old 11-07-2012, 02:54 PM
PaulS's Avatar
Yes it is, you are the winner of one dried up artist paint brush that I forgot to clean.
