Old 09-25-2012, 09:38 PM
Sugarmaker's Avatar
Red Paint,
Welcome! These cub folks will help you get going on your projects.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 09-25-2012, 09:42 PM
ajgross ajgross is offline
Inactive Member
Originally Posted by jrarick View Post
there is an extension spring on each side of the grill too hold it in place and yet still allows you to pull it back from the top to clean grass ect from the radiator screen.
DO NOT just pull back on that grille to clean something. There are two tabs on the bottom of it that WILL break off. When you get this back together and the radiator is in need of cleaning, you pull the screen back only enough to be able to lift it out of the holes it sits in. Then you just let it hang until you put it back in.
AJ
Old 09-26-2012, 08:08 AM
jrarick jrarick is offline
i just pull it back at the top just enough to get my hand in to brush off the debris.(engine not running) has worked for me thru the years although there are always other ways to do things. You can also pull the screen straight up and take it out to clean. Important thing is to keep it clean.
Old 09-26-2012, 10:55 AM
red56turbo's Avatar
Nice find on the 1772. You didn't get hurt at all at $400. Sweet deal. These 1772's are nice tractors. I love mine. Thanks for sharing the pics.
Josh
Diesel Cub Cadets...........
Old 09-26-2012, 12:11 PM
If you have not downloaded the manual for your tractor you should. Lots of good info in it like the plumbing.
http://www.onlycubcadets.net/forum/s...ad.php?t=13226
Old 09-26-2012, 10:14 PM
mrcubcadet's Avatar
Originally Posted by Red Paint View Post
Yep, I know where Richmond is. Been through there before on my way to buy a truck.
Already downloaded it off MTD's website. Going to print it out and put it in a binder here soon.
I checked the rear bolts earlier, and all were well tightened. Only three moved a slight amount. Good sign!
Today I finished the governor overhaul on the Super C, so tomorrow I will pull the Cub up to the shop and start major work to it.
Thanks all,
-Red Paint
Well, then you just might need to pay a visit sometime!
Get some more pictures of the Super C! We have a '53 Cub, '50 H, and a '65 706.
-105___ Tiller
Old 09-27-2012, 01:51 AM
Tater305's Avatar
Tater305 Tater305 is offline
good to know im close to some fellow cub owners if I ever need help or parts, I'm in Eaton,OH not far from ether of u
Old 09-30-2012, 09:21 PM
Check this link out.
http://www.onlycubcadets.net/forum/s...ad.php?t=14359
Use "Hytran Ultra" only for the tranny...available at your local Case/IH dealer.
Old 10-03-2012, 10:18 PM
Thanks for the update and pics.
Old 10-04-2012, 06:07 AM
Red Paint, on these engines you need to power up the glow plugs for 15 to 30 seconds and then hit the starter. Make sure your throttle assembly is working properly on the dash and you may need to give it full throttle at startup. Mine will start at 1/3 to 1/2 but yours may need more. If you have a Kubota dealer near you they should have a key. I purchased a complete switch assembly with two keys for I think about $35 from an online Kubota dealer. The batteries in mine are all lawn & garden tractor batteries with a high CCA. The original starters are not very good on these and there is an upgrade that you can do for about $125 with new glow plugs that are a must if your going to keep the tractor.
I wouldn't worry about the rear at this point because it sounds like the typical problems with it being loose at one time and there are some fixes for that.
The small yellow panel goes at the rear of the tunnel cover in the center of the fender pan. The black panel may go on the front side of the fuel tank but I can't tell because of the picture.
Good luck!
