Old 10-23-2012, 10:45 AM
Originally Posted by Little Jeep View Post
Thanks,, after giving it a second bath with degreaser last night, I added one quart of oil and it brought it to the full mark on dip stick. This morning, no puddle under the engine, so that is a good sign.
That's a great sign! Nothing makes me madder then having a oil leak.
Old 10-23-2012, 11:24 AM
Glad to have you!
Old 10-25-2012, 01:42 PM
Little Jeep's Avatar
Little Jeep Little Jeep is offline
Good News!! I got the Cub running today.... after it ran a while it was starting to sound pretty good. I drained and flushed the fuel system (tank, fuel hose, carb., etc.), the best I could before attempting to start it.
The bad news as far as I know now, is: The brakes do not work, also the brake pedal is missing a spring or something as the brake pedal goes down but does not return to the "up" position.. There is one skuff wheel and the entire mounting assembly missing from the mower deck, all the safety guards, and a PTO drive belt are missing from the mower deck, one of the pulley's below the front grill (runs the PTO belt) is damaged and will have to be replaced, the battery is toast, all the fluids & filters, including the transmission will need to be changed, plus every grease fitting on this tractor looks dry. Mowing season here is done for the year, so this will be one of my many "Winter Projects"... When I get ready to start, I'll write a "Build thread", even though there hopefully won't be much "building" to do.
Old 10-25-2012, 02:01 PM
That's great! Glad you got your cub running!
Old 10-25-2012, 02:09 PM
X2!
Old 10-25-2012, 02:23 PM
X2!
Thanks, guys!! I'm excited about it as well....
Old 10-25-2012, 06:31 PM
I'm excited for ya too!
Old 11-26-2012, 05:17 PM
Where is a good place to buy parts for a Cub that won't break the bank... I need one of the pulleys that sits under grill (PTO belt to belly mower runs thru it), I will also need brake pads/shoes, and probably some/all of the hardware, the spring? that returns pedal to "up" position, transmission/rear diff(?) fluids, plus a caster wheel assembly for the belly mower. I figure the battery can be purchased through my local auto parts supplier.
I haven't touched the tractor since the day I got it running, so I won't know exactly what is going on with the brakes until I pull them apart for inspection.
Old 11-26-2012, 07:51 PM
garrynok's Avatar
garrynok garrynok is offline
Congrats on your cubs and welcome to the forum. You came to the right place to get info. I lived in Owensboro, KY for about seven years and really enjoyed my stay there!
Garry
Old 11-26-2012, 10:00 PM
I have Jeep buds that live in Owensboro.
