Are you using the correct weight of oil? Hydraulic lifters are a bit picky with oil...I think the Kohler Commands need 10W30 above 32 degrees F.
Mattg
Lawnmower had betting setting for a while. Yes i put new oil 10w/30w plus new filter, new gas. Lawnmower started and ran great the first 7 or 8 times. Then started to backfire through the carburator when you tried to start it. I think now we have narrowed it down to a bad hydrolic lifter. Thanks for the help.
Walter |
Rhoderman
Thanks for the information about the parts. I ordered them from the same place you got yours from. Parts will be here thursday. I have it narrowed down to the hydrolic lifters. The parts from them are a whole lot cheeper than they are here. And for the same part numbers. Will let you know how it turns out. THANKS AGAIN.
Walter |
RHODERMAN
Got my lifters and pushrod in the kohler engine last night. The engine fired right, no backfiring through the carburator. The motor runs great. Thankas for all the help. Thanks Again
Walter |
Cool! Glad that was all it took.
Did they send you the solid pushrods? Were your old ones solid or did they have holes in the ends? My originals had holes, and the new ones didn't. I heard that was an issue and they had changed. |
RHODERMAN
They sent the new solid pushrods. We thought that the reason they replaced them was maybee the other ones were flexing. But anyways the motor is running great. Thanks again for the advice and help.
Walter |
