Old 11-03-2012, 12:23 AM
young enthusiest's Avatar
another solution is to take the pan off, and drill out the bolt holes. The ones in my 1650 are now 7/16 fine thread, tightened almost to the point of stripping. I used brand new bolts and washers. That tractor shakes like a (bad shaking tractor) at all speeds accept WOT.
good luck
Old 11-03-2012, 07:49 AM
BigB87's Avatar
BigB87 BigB87 is offline
alright. ill look around and see if i cant find one. for now i put some locktite on them to hold them in place, its a low strength so it wont take much to break them apart again.
Brandon
CC models: 86, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 11-03-2012, 11:18 PM
samiam44 samiam44 is offline
I've done quite a bit of helicoiling in my day-
I will say they are used on all aerospace applications for a long time. Good product and you can get an automotive kit for the bolts from amazon for $18 or so. I would do both LHS bolts. If the pan has severe wear on the bottom- you might consider replacing it.
Helicoil is stronger as it provides better load distribution to the first few threads which take most of the load and it effectively is a bolt size bigger.
I just did a bolt on my 1650 as it was stripped.
I tried finding a decent pan on ebay- BECAREFUL. Most of those used lawnmower guys say in their write-up- no warrantee.
I got a cast iron pan and it had a HUGE crack. Twice the guy insisted it was free upgrade and he would give me the "superior" aluminum pan. Dispute and he *had* to get his pan back with the huge crack... Ordered up an aluminum one from Patton's and it was useable but had a stripped thread.
Michael
Michael
Old 11-04-2012, 10:50 AM
BigB87's Avatar
ill keep tht in mind when looking for a pan, but i mite helicoil it. everyone seems to go tht route
Brandon
Old 11-18-2012, 12:40 AM
BigB87's Avatar
Just wanted to give all yall who helped me out. I finally got a new pan (aluminum) with good threads, got new bolts, and done the craddle mod with it still in the mower after I took the motor out. I'll tell ya wat before my 1650 wuldnt even pull the front tires off the ground now she pulls them a foot off the ground. the engine is nice and solid in the frame. i used grade 5 bolts, lock washers and thread tape. thank yall so much for the info and help.
Brandon
Old 11-18-2012, 11:19 AM
Brandon glad ya got it fixed!
Old 11-18-2012, 06:17 PM
BigB87's Avatar
Thanks Duke! she is stout as ever now. may only have a 14hp in her now but lookin for a new 16hp.
Brandon
Old 11-18-2012, 07:57 PM
Congrats on getting it fixed!
Old 11-19-2012, 02:42 AM
BigB87's Avatar
Thanks ACecil! im super excited now. took me 4 hrs but well worth the pay off
Brandon
