Old 11-15-2012, 05:16 PM
bill682 bill682 is offline
Yes the K161T had a stator. You will probably find the coil badly cracked once you pull the flywheel. A new coil is hard to find and expensive but if it were my Grandpa's tractor I would fix it.
Old 11-15-2012, 06:53 PM
As someone that knows very little about the early Cubs would this likely be an early serial number O?
And I agree if it was my grandfathers I would keep it and try to restore it.
Mac
Old 11-15-2012, 07:07 PM
Cool
It is not a stator.It is a magneto for clarification purposes. Yes they do crack but before you pull the flywheel, put a new set of points,gap them to .020 put a new condenser on it and give it a few pulls while holding the end of the spark plug wire in your hand and see what happens.
Unless you have a spark tester....
Hope this helps
Old 11-15-2012, 07:15 PM
The condenser is also behind the flywheel.
Old 11-15-2012, 07:55 PM
Yes it is...my recoil 72 has it on the outside.
Bill
Like I said I know very little about the early Cubs. I do love Old Iron. Any chance you have pics of the engine under the flywheel?
Thanks
Mac
Old 11-15-2012, 08:18 PM
NateSav NateSav is offline
Alright so i think this is my plan, new points, condenser and possibly plug wire. I was talking to a buddy of mine and he recommended something to the point that it does have an on/off switch on it that shuts the tractor off, and the dang switch is so corroded it cant even read which way is on or off.(but yes i did try starting it in both positions) Unfortunately, hunting season starts on saturday up here in new york, so it doesn't look like too much will be going on until monday night, but hopefully sooner than later. And good luck to all the guys going out on opening day!
Savells
Old 11-15-2012, 08:42 PM
No, but I wish I did 10 years ago. It's very tight under the flywheel. This pic is very similar.
Old 11-15-2012, 08:54 PM
Bill
Thanks for that one. Most of the stuff I do is mid 80's and up. Love old earth moving equipment from the late 40's and up. Nothing like a NorthWest 80D with a Murphy diesel.
Old 03-09-2013, 03:14 PM
well, finally got back outside today to try and mess around with that tractor since its a nice day and the sun is out. sprayed some starting fluid in the spark plug hole, and pulled it once, got a small pop, pulled it a third time and got a loud pop out of the engine then after about 10 more pulls nothing happened. Not really sure what to do next, any tips or tricks would be appreciated. thanks.
Savells
