Old 12-02-2012, 12:14 PM
Sugarmaker's Avatar
That's a really nice fabrication! Great work! I could use one too!
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 12-04-2012, 02:35 PM
Shaner Shaner is offline
thats next on my build list. maybe instead of getting rid of the casters, you could build little boxes around the top of them, almost like a shield. im guessing those casters make rolling that table around a dream, i wouldn't wanna get rid of them. but shields on the top and all four sides would prevent any falling slag or molten metal from contacting the top of the casters. sheet metal would work great for that.
Old 12-29-2012, 09:13 PM
inboardnut's Avatar
inboardnut inboardnut is offline
I finally got time to get the receiver cut into the table. I decided to go thru the top itself.
I cut a square hole just large enough to allow the outside of the receiver to go thru.
I welded a 5/8 nut over the pin hole for a "tightening bolt". Then welded the receiver in place. I left it about 3/16" below the surface. I made a removable plug out of 3/16" steel to cover the opening if nothing is in the receiver.
I used 1/2" thick plate to make the vise mount. Drilled and tapped it for 1/2" bolts.
Welded a 2" tube to the bottom...
Bolted the vise ( My Christmas present ) to the plate....
Also made an anvil out of an old rail..
Next up will be mounts for a grinder and buffer.
Old 12-29-2012, 10:26 PM
Very nice workmanship! Thanks for the pics.
Old 12-29-2012, 10:43 PM
Well said!
Old 12-30-2012, 06:11 AM
nikster's Avatar
nikster nikster is offline
Great job!
NIK,
