Old 11-29-2012, 10:50 AM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Adam you've got some cleaning to do! Looking good tho.
Good thing I have a pressure washer! Going to try to clean it up after school tonite!
Old 11-29-2012, 08:34 PM
TheIHMan's Avatar
I pressure washed the frame, took the front axle off and sanded the frame. Tomorrow night I'm going to paint the frame RED! Pics tomorrow!
Old 11-29-2012, 10:11 PM
Sounds like a plan, Adam!
Old 11-30-2012, 11:16 PM
TheIHMan's Avatar
Well I tried to paint the frame tonight. Started fine but then the paint started to run like crazy. So I went ahead and put 1 good coat on and it ran some more. I'll let it set for about 2 weeks and then wet sand it and try to paint it again. Next week's project will be to clean up the rearend and front axle and paint those, and if I get around to it I'll pull the Mag 18 out of the 1811 parts tractor, put a new oil pan gasket on it and maybe even paint it. Here's pics
Old 11-30-2012, 11:20 PM
Thanks for the pics, Adam! You'll get it!
Old 11-30-2012, 11:23 PM
TheIHMan's Avatar
I hope so! I think I put a little too much thinner in the paint.
Old 11-30-2012, 11:40 PM
Oh the look of fresh red paint.
Old 12-01-2012, 06:15 AM
Looking good Adam!
Old 01-20-2013, 10:10 AM
TheIHMan's Avatar
Well, I was finally able to do some more work on the cub yesterday. It was warm outside so I pressure washed the rear end, tires, and hoods. I also pulled the Mag 18 out of the 1811 parts cub. Found the oil leak on the Mag 18 too!. I thought it was the engine seal but once I got to looking at it I saw something happened to the oil plug and one of the PO's put a pipe with a cap on the end for the oil plug. It would of worked fine if the engine never had to be pulled and if they used thread sealer. So now I just have to pull the plug out of the KT 17 that came out of the 1711 and put it in the Mag 18! Hopefully this week I will resand the frame and repaint it. And if things work out I'll paint the rear end and front axle also.
Old 01-20-2013, 10:15 AM
Nice job on the updates and easy fix on the mag 18 too.
