I felt sure you were going to say the pipe was a friction fit and a little twist would remove it. If you can't actually open the hood how do you check oil level or clean the air filter, something that I have to do quite often.
It is a friction fit but to get to the bolts, I leave the stack up on the pipe alittle bit so I can lift up the hide enough to take the bolts out of the side panels take them off then get to the bolts. Sounds like a lot of work but putting it back together is the hard part.
Kris 63 CC Original w/ 38” deck and front plow 72 129 50” deck, 42” blade 73 86 42” deck, 42” blade 84 CC 680 w/50” deck and 42" plow 89 CC 1811 46GT" deck,QA42A, 38" IH 1A tiller, Brinley-Hardy plow x2 1982 Gilson Lawn Tractor with 38" deck ![]() |
Kris,
Nice 680! The big tractor stack fits real well and is a nice clean installation. Yep, it was worth the wait. Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
Yeah it fits real nice. Used a hole saw to cut the hole, then used steel pipe fittings and pipe to run it thro the hood.
