I was thinking poor battery as well.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
well i gota go to the farm store in a couple days any way i guess ill look in to a new battery what kind of cca should i be looking for it a 12 hp
The higher the better... I got a little 275 I think it is on ny 123 and does fine. Got a 360 on the original and can defntly tell the difference
X2 on the highest CCA you can get. I went to my local TSC and got this one; http://www.tractorsupply.com/mower-b...g-amps-4700042 it turns over my 14 HP well.
Other things I checked when I was having problems with mine: grounds are all cleaned up, and tight. Spark plug gap is correct points are gapped correctly I use 93 octane fuel in winter, it helps park it inside, or get a heater for your rear end I also put a batt. tender on my battery to ensure it's good before i want to start it.
I would do as Matt says,make sure you points are good and do the static timing.I did not believe it till I tried it and now would not do anything else.The 123 I had would start so much better after ,like night and day.
Bob |
new battery is in contacts on the battery are good haven't checked others yet and im still having the same problem
changed out the s/g and wow what a difference it cranks over so much faster now and starts right up
thanks also did a carb cleaning
My tractor, a 126, has this starting issue. What is this s/g you speak of?
IH CC 126 with 38" deck |
