Old 01-21-2013, 06:05 AM
rmunro's Avatar
rmunro rmunro is offline
Mine are P rated on the 1500. But the are TRUCK/SUV/CUV tires. They are tougher than a car tire. They are rated for higher weights and pressure.
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 01-21-2013, 09:08 AM
cub123's Avatar
cub123 cub123 is offline
I put the BF Goodrich T/A KO on my wrangler, they ride smooth, quiet, and have good traction. Not the cheapest tire, but they have been making them for a while, and they are kevlar reinforced
Old 01-22-2013, 08:10 PM
Wild Bill's Avatar
Wild Bill Wild Bill is offline
The Suburban weights over 5,300lb 'dry' add oil, front and rear differential fluid, transfer case fluid, transmission fluid, and 42 gallons of gas....plus up to 9 passengers (not to mention XX lbs. of cargo, and XX lbs. of a trailer), and you get - I'm not putting anything less than LT rated tires on it.
Keep in mind, I don't want A-T tires/tread. Since I've bought the pickup truck, it sees the 'off road duty'. The Suburban will stay on the pavement from now on........
Original OCC Super Mod....and former OCC Co-Admin.
I was hacked........
Old 01-22-2013, 10:01 PM
Merk Merk is offline
I ran a Cooper brand tire on my 99 Chevy Suburban. They had a highway tread and were a 6 ply tire. Traction wasn't a issue unless the 45 galion gas tank was almost empty and pavement was wet. I was getting 70000 to 80000 miles on a set of tires. The ride was good and the tires were quiet. I pulled a 30 foot camper and a 16 foot cargo trailer with my Suburban.
The Suburban was traded off on a new Chevy 2500 HD pickup last April.
Project Uncle Dick
Cub Cadet 70
Old 01-23-2013, 06:28 PM
Wild Bill's Avatar
Thanks Dale!
I did some more research on tires made by Cooper...and found the 'Mastercraft' brand.
I'm leaning towards the Courser HTR, or the HSX Tour. I'm thinking Load Range C will be plenty, but they also offer a Load Range E in the LT245-75-16 size..............
Old 01-23-2013, 07:51 PM
Bill,
Glad to be some help.
I think my tires were the Mastercraft brand. Suburban was traded for current truck last April.
My Suburban had 15 inch tires. It was only a 2 wheel drive.
Project Uncle Dick
Cub Cadet 70
Old 01-24-2013, 07:51 AM
rmunro's Avatar
Load range E is 10 ply rated tire. The load rating is only meaningful if run at recommended PSI, which is 80PSI. On a 1500, the original rims may not be rated for that high pressure.
Load range C should be more than adequate for you.
