Old 02-03-2013, 06:40 PM
bkw3614 bkw3614 is offline
I agree with the others. A couple of hundred bucks is generous for that machine. If it is a 1200, it may be worth $225. Not running and not turning over is a major red flag to me. I would be afraid of a siezed engine. I think I would offer a hundred bucks and run if he says no. If he can get that $1200 for that tractor, then I would have to say: "There is a sucker born every minute."
Old 02-03-2013, 09:06 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
im picking up 2 1650's both dual lift. one runs good , other no engine parts tractor.
asking 300.00 for both. the good ones are out there. you just got to wait till you find it.
Doug
Original , 100 , 125 , 582
Old 02-03-2013, 09:26 PM
rusmart rusmart is offline
Called and he says it will 'click' when you try to start it. They put a battery charger on it, and it does the same thing. It sounds like they haven't tried a whole lot to get it started (but that's typically what they say I reckon). Either a bad battery or a seized motor. One is easy, and the other is a huge deal!
A 126 with an IH snowblade was for sale here locally for $500. Had a recently rebuilt motor and a repainted frame. Was missing the stuff for the front PTO though. I think it's still for sale, so I'm pretty sure this tractor with the tiller won't sell for more than $500 not running.
I guess a cool thing is that this tractor for sale can use the front craftsman blade independent of raising and lowering the tiller. I'll have to look and see if they botched up the frame to attach the substitute blade. I'd much rather use the heavier IH blade if possible though.
Russell
Cub Cadet Original w/ 3pt
Cub Cadet Original w/ fenders, creeper, & 3pt
Cub 100 w/ 3pt
Cub 125 w/ 3pt
NF Blade, cultivator, brinly plow, 38" & 42" deck, disc, tiller
Old 02-04-2013, 12:41 AM
That's far more likely to be a bad solenoid or wiring than a seized engine.
Old 02-04-2013, 01:17 AM
Hmmmm, I just sent an email asking him to see if the engine will turn over by hand and if it still has noticeable compression. I asked on the phone, but he didn't know. I mentioned it could be a bad battery, bad wiring, or a seized motor on the phone with him. I'll probably make the trip sometime this coming week if it seems a deal can be reached.
I don't mean to give a lowball offer, but I don't want to be ripped off
Thanks for the tip about the solenoid Matt! I'll have to check that out. I had a car that you had to tap the starter solenoid occasionally to get it to start.
Doug! I'm jealous, a 1650 or a even 149 would be great! Maybe more will start popping up for sale during the summer. I've used a 109 with a hydralic lift and it's so easy raise and lower stuff.
Is the tiller a bear to raise and lower manually? I'm okay if it takes some effort, but will it take considerable effort?
Russell
Cub 100 w/ 3pt
Cub 125 w/ 3pt
Old 02-04-2013, 04:43 AM
4SPEED's Avatar
if you have a spring assist on your manual lift , your tiller will come up easy.
Doug
Old 02-04-2013, 09:22 AM
EasiER IMO....although the last time I lifted a tiller + spring assist it I was probably 14 and don't have the arm strength like I do at 28.
Old 02-04-2013, 11:32 AM
red56turbo's Avatar
That is high on the price. Hopefully you can work out a deal. Wave some green in front of his face, not $1200 of course, and see what happens.
Josh
Diesel Cub Cadets...........
Old 02-04-2013, 01:00 PM
IH Cub Cadet IH Cub Cadet is offline
Price sounds really high.
I've got a 1650 I am piecing together and here are some of my observations.
1. ISO mounts can be a pain in the arse, however, if you do the cradle mod, you shouldn't have to revisit them for a long long time.
2. The exhaust tin and mounting of it is kind of a pain - but again if you get it together, it should be OK long term.
3. QL's are wide frame, so easier to get at the tranny/drive shaft guts via removable cover on top of the mid-section of the tractor.
4. IMHO, QL's are everybit as heavy duty as any other IHCC. They can be a hassle to get repaired, i.e. ISO mounts, but once all that stuff is fixed, you got good machine.
Good luck,
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 02-04-2013, 01:52 PM
Leadslingingdaddy's Avatar
Way too much work involved there to try and give someone some money for a product they are trying to sell.....Run Away Runa Away fast....Too many others out there.
