Old 02-17-2013, 06:43 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
Originally Posted by Shaner View Post
Looks good. I would suggest hard facing the teeth on those shanks. As well as the bottom of the box itself. It will hold up allot better. Hard facing rod for a stick welder is available at tsc. Good fab work. I really like that 189
or S/S wire works good too. and doesn't rust
Doug
Original , 100 , 125 , 582
Old 03-03-2013, 10:02 AM
Bum454ss Bum454ss is offline
would it be possible to do this with my 126? I have the sleeve hitch setup now.. but to be honest I'm a little confused on the meaning of CAT 0 and CAT 3? Sorry to get off topic. That is an awsome setup!
Old 03-03-2013, 12:49 PM
fourinchdragslicks fourinchdragslicks is offline
CAT 0 is the smallest of the 3 point hitchs, reserved for tractors under 25 hp (IIRC) it uses 2 lower arms that lift the implement, and a top link that is used to adjust the angle that the implement engages the ground. cat 1, 2, 4 are just larger 3 point standards for higher hp tractors with larger (heavier) implements
Old 03-03-2013, 12:51 PM
if you want to see some really well made 3 point addons look at xtrememotorworks.com although there are some pretty decent ones made by members on here, but i don't have links for the threads right off
Old 03-03-2013, 07:13 PM
Grampie Grampie is offline
Default Box Blade Build
A super nice job ! I like the heaver diamond plate. I think it'll work in you're favor with the extra weight / strength . Are you're tires filled? That would really help you're traction & don't cost alot-a-cash either. Again, nice job !
Old 03-07-2013, 09:44 PM
CubNub's Avatar
CubNub CubNub is offline
Thats an awesome box blade! Great job and craftsmanship!!
Old 08-28-2015, 11:41 PM
johns cubs's Avatar
johns cubs johns cubs is offline
I know this is an old thread but i tried sending Chip a PM from my phone and not sure if it worked. Was just looking for update as to how this project turned out and looking for tip on box blade build project.
John
Old 10-05-2015, 05:02 PM
CadetTommy's Avatar
CadetTommy CadetTommy is offline
Box blade looks great, and that Cub looks tough with those big wheels on it!
Edit: Did not know this thread was as old as it is.
'74 IHCC 108 - 38A, supersteer axle
'75 IHCC 1000 - 44A, Sears wheel weights
'87 CC 1872 and 1811 - Haban, 44C
'96 CC 1863 - 54GT
'79 JD 400 - 60" deck
"Projects" '67 123, '65 102, '71 126
