Old 02-17-2013, 11:21 AM
CubNub's Avatar
CubNub CubNub is offline
So far, so good! Dont you just hate getting into the cub then having something to do. I end up thinking about it all day.
Old 02-17-2013, 11:37 AM
TheSaturnV's Avatar
Ditto. We often have family activities that get planned around the 12-2pm time frame. Cuts the Cub work day smack in two!
Vartz04, mind your grill doesn't flip that work bench over and catapult your drill across the garage!
Old 02-17-2013, 11:54 AM
vartz04 vartz04 is offline
Haha. It won't. There is a welder on the bottom shelf opposite side.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 02-17-2013, 05:45 PM
Snuck out and got the gas tank pulled and drained. Need to get that motor out ASAP so I can order parts and then I can work on the rest. The motor is going to control the schedule of this project. I'm really happy how easily everything is coming apart. So far only one rounded nut that just needed some vise grip actio. I am actually finding a lot of loose fastners.
Old 02-18-2013, 10:01 AM
Should be picking up a rear lift this week for it. Out of town for work tonight so I wont be getting any work done today or tomorrow. I'm hoping the lift is still avail on Wednesday.
I also ordered a throwout bearing as that was one of the things you guys suggested replacing.
Old 02-19-2013, 10:13 PM
Got my garage clock today
Old 02-20-2013, 06:43 AM
Nice looking clock!
Old 02-20-2013, 07:38 PM
Been out in the garage workin on her for the past 2 hours or so. Got the motor pulled, Head pulled off and started doing some inspection. I need to go to my parents house and get some tools to get it torn out the rest of the way for inspection but I think I found the culprit for the oil burning/smoking.
Here is a pic of the tractor as it sits now. I am going to grab the sand blaster from my parents as well and I will start taking the rest of the tractor apart once I figure out what I am doing with the motor. I want to get the motor done and then start painting.
Dont mind my weim sitting their enjoying a bone while I work
I am guessing this is why it was smoking. Also the head bolts werent tight
Cylinder walls look really good and what I could measure without pulling the piston yet was within spec of the piston size.
And here is why it looks good
already bored .030 over
How come the back side of my 3 pin driver looks like this? Should I be looking for a new one?
So with the above photos and the cyl being spot on for .030 I am going to go ahead and just replace gaskets and put it back together. I believe the reason for the oil burning is the blown head gasket as everything else in the motor looks nice. I will check out the rings when I get the piston pulled. If it was your motor would that be where you stop or would you get a full rebuild kit for it? after I get the rod out I will be able to tell if the crank was ground yet but if it was and the rod was replaced im done with that. It does look like i need some valve work though but gaskets and the valves are much cheaper than a whole rebuild kit and the connecting rod.
Old 02-20-2013, 07:48 PM
Complete brain fart. I just realized all I had to do was pup off 2 bolts and pull the pistion/rod. Rod is new crank was ground .010. Rings look brand new and none are stuck. Measured the bore again and it is all within spec of being bored .030 over.
Old 02-20-2013, 10:07 PM
You've been busy! Thanks for the update and pics.
