Old 03-07-2013, 09:13 PM
cubby102's Avatar
cubby102 cubby102 is offline
I don't see why you couldn't punch the small bore block out to the newer style. IIRC I read somewhere that oohler went to the new bore to make it cheaper between building the k161 and k181 talk to you.machining guy he should be able to tell you
Old 03-07-2013, 09:44 PM
The 28542 Engine used a 2-7/8" (2.875) STD Piston. The newer K-161 used 2-15/16 (2.938).
Here are the Pistons available:
41-874-01 = STD
41-874-02 = .010
41-874-03 = .020
41-874-04 = .030
You could bore to the STD (2.938) if you wanted.
