Old 03-11-2013, 03:48 PM
red56turbo's Avatar
Thanks guys. Hope to tinker around with it this week, replace with a correct ignition switch, and try to get her running without jumping the switch. We'll see.
Josh
Diesel Cub Cadets...........
Old 03-11-2013, 04:33 PM
dag1450 dag1450 is offline
Looks like a nice package deal. Every Haban i ever see has the white big bore cylinder ,i dont know who made them but it does seem like that was supplied by cub. The small bore power angle cylinder was for the 14 and 1650. Im not sure what size bore was used in the early 80's or when they changed to the larger. Dave
Old 03-11-2013, 09:39 PM
EricR's Avatar
EricR EricR is offline
Me likes it to!
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 03-11-2013, 11:24 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Josh, when I got the Haban blade for my 1572, I also had the extra manual blade parts and the white angle hydraulic cylinder, right out of the box from CC. I always got my attachments in the box from the dealer and assembled them myself, right in the garage. I love those days!!!
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 03-12-2013, 02:31 AM
squatch squatch is offline
Nice score! My Haban blade has the white cylinder as well.
Make sure you use the rock shaft brace with that heavy blade!
Trust me you don't want to replace a broken rock shaft on a Super!
Old 03-12-2013, 07:22 AM
X2!
Old 03-12-2013, 01:36 PM
red56turbo's Avatar
Thanks guys for all the comments!
Frank,
Thanks for the info on the cylinder. It has the large CC white cylinder. The PO even had the IH blade mounting blocks in a box with the 1872. I believe all the manual tilt stuff for the blade is there as well. Suprised the PO didn't chuck it.
Squatch,
Thanks for the brace info. Never would've known that. Probably would've found that out the hard way.
Josh
Old 03-14-2013, 05:37 AM
That's how I found out! I hit an immovable object buried in the snow at speed. Oh yeah, there is another hint. You only want 2 of the 4 trip springs on the blade when pushing snow. Only need all 4 for heavy dirt work at low speeds.
Old 03-14-2013, 11:33 AM
FrankF3's Avatar
squatch, I don't remember ever having or installing the support bracket for the rock shaft support. I still have all the pieces from the original install from the late 80's around here somewhere. Just have to find it! I'll see if it still available from my dealer. You know I was looking the other day for some part, and I was saddened to see that in most cases, there are very parts left that are available should you need to repair something.
I have a 48" Haban rear PTO powered tiller that is a story or thread of its own but all that is available for that is a bearing or two and some nuts and washers should it ever need something...
Old 03-14-2013, 01:00 PM
kennell kennell is offline
Gotta love the supers. Great snag. Kent
