Old 03-22-2013, 08:21 AM
jdroison jdroison is offline
Thumbs up
I use it in all my tractors and even add a half can to the oil in my 99 chevy suburban, keeps the lifters from sticking in those vor-tec engines.
in the 1811 it seems to run quieter.
Cub Cadets & IH tractors
1811 - 1090 hours
1872 basket case, rebuilding.
#1 tiller
1 Farmall regular
Old 03-22-2013, 09:57 AM
Originally Posted by Grampie View Post
Oak, Why would you put anymore in than the directions call for?
The Startron is for the gas and the MMO for the engine. I'm probably wasting money with the MMO.
Old 03-22-2013, 11:38 AM
LiamD's Avatar
LiamD LiamD is offline
Default Sea foam
I use MMO startron and sea foam as well as high octane fuel.
I have never had a problem and they always start even on the coldest days.
Mike
Old 03-22-2013, 11:53 AM
SeaFoam is designed as a additive to oil to clean out small oil passages ,has a friction reducer that glazes metal surfaces slightly reducing drag regular use ( all the time ) tests have proven slightly less bearing& ring wear over time- 500 hours . GM top engine cleaner is the main active ingredient in all these GM top engine cleaner is the best/ strongest injector cleaner I have found usually the cheapest too. On the fuel side I would use a fuel cleaner, many available . lots cheaper than 8.99
yes used it a lot in car dealership mostly to free or clean up hydro lifters.
As a solvent it will thin your oil down
I prefer the Justice bros engine tune up with friction modifier, there demonstration is cool, but hard to find here
Old 03-22-2013, 12:59 PM
nikster's Avatar
nikster nikster is offline
Had an issue when I 1st. Got my # 122. To lazy to rebuild carb & clean out the bowl. Ran a minimum amount of sea foam to clean it up a bit. Ran fine but then I found out about StarTron. Been running it in all my cubbies, & seem to run happier.
NIK,
Old 03-22-2013, 01:40 PM
macman81's Avatar
macman81 macman81 is offline
Originally Posted by Donovan M. View Post
I just wish it wasn't nine bucks a can.
for what its worth i work at car quest and we have been selling it for 7.99/can for at least six months now.
i use it in all my small engines on a regular basis and have no bad gas issues.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 03-22-2013, 01:56 PM
Shaner Shaner is offline
i put seafoam in my trucks. its like prune juice for engines. cleans them right out! ive noticed a difference in the way they run after running seafoam.
Old 03-22-2013, 05:41 PM
cuber cuber is offline
I run SEAFOAM in all of my gasoline engines and my boat engine. I love the stuff and it even smells good coming out of the exhaust!!!
