I've played around with reducing valve spring tension on stockers with some success . the stock springs are good to 5000 or so before they start to float. less spring tension = less drag . left the second ring off the piston for the same reason. little things here and there add up.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
.040 between the valves and the head. if you keep the stock head gasket there should be plenty of room above the piston to the head for clearence
Can't wait to hear and see this Kelly.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
Donovan maybe fall plow day in western NY you can give her a whirl.
