Old 04-11-2013, 09:23 AM
macman81's Avatar
macman81 macman81 is offline
those front wheel kits make a HUGE difference in the cut quality! i too am a fan of gator mulching blades but ive never tried to find for my 44a deck. have them on my 50c and will never go back.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 04-11-2013, 09:58 AM
The deck looks great! Let us know which way you go with your blades.
Old 04-11-2013, 05:30 PM
scgtguy's Avatar
scgtguy scgtguy is offline
Default Gator mulcher's
I'm going to install the gator mulcher blades ... they look like they have alot of sharp blade surface .... and all thos extra cutters on the aft end also look pretty heavy duty.
Also if one of you guys could update me on proper blade mount installation ... is one of those heavy washers on both top and bottom of blade followed by the large nut ... or should you also have a lock washer under the nut. How was it done from the factory ? ... i've never seen a parts diagram for it.
tks, B.
Old 04-11-2013, 07:14 PM
sawdustdad's Avatar
I normally use one washer under and one on top of the blade, followed by the nut. I use an impact wrench with a 1-1/8 inch socket to take them off and put them back on.
I'm not sure if this is the correct way to do it, but that's what I do.
Old 04-11-2013, 07:37 PM
scgtguy's Avatar
Default blades ...
sawdust ..... that sounds good, when I got mine it was hodge podged. I've got an electric impact gun ... i'll use it to tighten them down.
took a few pics this evening before I knock the shine off the deck this spring.
looking forward to getting the pulleys and blades vis UPS .... that guy is my buddy.
Old 04-11-2013, 10:07 PM
EricR's Avatar
EricR EricR is offline
Great looking tractor Bryan!
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 04-11-2013, 10:15 PM
Sharp tractor and deck!
Old 04-12-2013, 06:19 AM
What Eric said!
Old 04-12-2013, 02:23 PM
She looks like she's ready for mowing duty!
Old 04-12-2013, 03:13 PM
Grampie Grampie is offline
scgtguy, Nice pictures! I really like the way you have your rear hitch with the tow ball ahead of the hitch hole. Nice!
