Old 04-15-2013, 12:08 AM
Thanks Allen and Josh.
This one will be going on the dual stick 1650.
That works as well, Todd!
Old 04-15-2013, 07:05 AM
Grampie Grampie is offline
Very nice Todd! Your going to Like It, Alot!
Old 04-15-2013, 09:41 AM
Todd you need a cab now so you can really get the full enjoyment out of it.
Old 04-15-2013, 02:54 PM
nice blade todd
Old 04-15-2013, 08:17 PM
CubyFan CubyFan is offline
Is that a recent picture of the 54" plow? It's the middle of April and you still have that much white stuff I'm sure you will find some kind of use for it. I had a 169 sitting ready with a blower and a 149 with a plow and not enough snow to use either one this winter. Maybe you can send some white stuff our way next winter.
Cheers, Rick
Old 05-08-2013, 08:38 PM
Sugarmaker's Avatar
Todd,
That is a nice power blade. I assume that you have it in clean up mode?
Hope that snow in the pictures has melted and your busy mowing grass. Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 05-08-2013, 09:21 PM
Mounted up the push blade to test fit everything before getting it sand blasted. Thought about just taking it in after getting the sub frame figured out, but I thought I had better see if everything works together. Well........
It worked fine until the coil pin on the inside right hand arm assembly on the rockshaft broke
Anyone have an idea how to get at it to get it out? There's no room from the top, and the frame is on the bottom in the way.
I haven't tried the hydraulic cylinder swivel yet, one thing at a time
Old 05-08-2013, 09:35 PM
cuber cuber is offline
I just replaced that exact same roll pin on my 1650 last weekend. I was able to remove a small piece from the top side and a small piece from the bottom, but then there was still a big piece stuck in the middle. So I ended up removing the right side foot rest and the outer rockshaft lift cam thingy which also had a broken roll pin. Then I sprayed a lot of PB Blaster on the rock shaft arm and was able to slide the big dowel out threw the right side of the frame just enough so I could swing a hammer and remove the rest of the roll pins that were stuck in the dowel. Hope this makes sense and helps you out... Oh and I also cursed a lot of swear/cuse words too, it didn't help much LOL
Forgot to mention I also removed the pin from the hydro cylinder and flipped that bracket up out of the way.
Old 05-08-2013, 09:48 PM
That blade looks great on the tractor zippy1
Hope you get the roll pin problem fixed quickly.
Old 05-08-2013, 10:11 PM
The 1650 and blade look nice, Todd!
