Old 06-09-2013, 12:08 AM
rweaver rweaver is offline
one thing to check is make sure insides of the pulleys are smooth looks like your pto and mule drive pulleys look good one on the deck I cant see from your pics the other thing is if you center bearing is going out it will let the pulley come forward and run the belt on a angle and wear the belt and what number belt you running on your mule drive should be a 3003a if I remember right
Old 06-09-2013, 07:03 AM
how can I narrow down if it's the center pulley or the mule drive pulleys, or even the clutch pulley?
The pulley that does NOT spin freely. If there is resistance, noisy or wobble, time for repairs.
Old 06-10-2013, 06:24 PM
inspectorudy's Avatar
When my long deck drive belt failed a couple of years ago it turned out to be the spring loaded idler that was bad. If there bearings in it do not allow it to flex as it need too then it will cause rubbing and the belt will fray and then fail.
1811 Hydro
Tags
782, belt, deck
