Old 04-27-2013, 03:13 PM
JK777's Avatar
JK777 JK777 is offline
Originally Posted by Peruvian View Post
If you have the dimensions/specs/etc, could you post them? I'd like to ask a local fab shop what it would run to have them make one of these for me.
Thanks!
Yes. I just have not got around to it yet. This project can be made with just a drill, welder, and cutting wheel on a grinder. Most steel suppliers can cut the parts to length for you at a small fee.
Old 04-27-2013, 03:47 PM
Peruvian Peruvian is offline
Much appreciated. Can you get any down pressure with it or is it just the weight of the box that's scraping? Are you adding slots to the square tube for ripper teeth?
Old 04-27-2013, 08:38 PM
JK777's Avatar
Yes, l can get down pressure. And as far as rippers go I can add them but I'm not sure if I'm going to on this one
Old 04-28-2013, 06:25 PM
Sugarmaker's Avatar
JK777,
Great fabrication work! Thanks for posting these shots as you built the box scraper. Yep paint and action photos would be great when you get a chance
Regard,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 04-29-2013, 12:00 AM
JK777's Avatar
Some action shots from today. I had to clean up the yard, first I plowed the whole thing then ran the box. It worked better then I expected.
Old 04-29-2013, 06:07 AM
Turned out great!
Old 04-29-2013, 11:35 AM
That is awesome! Glad it did a nice job for you!
Old 05-20-2013, 09:44 PM
seawalkersee seawalkersee is offline
Pardon my ignorance, but what is the point of the box? Is there some sort of use for this like to roll over the gravel on driveways as well? My parents have a gravel drive and it is starting to get overgrown and needs to be turned....
SWS
Old 05-20-2013, 09:52 PM
The point of the box is it holds the material your handling so it can be spread evenly. A regular blade has a tendency to let the material "roll" off the ends of the blade. If you need to roll over the gravel in a drive, a regular blade that can be angled is what you need.
Old 05-20-2013, 10:40 PM
Actually, having BOTH is nice!!
NEXT PROJECT!!
