Old 04-28-2013, 07:12 PM
SumBum's Avatar
SumBum SumBum is offline
Sweet Smoker.
Old 04-28-2013, 07:31 PM
Originally Posted by ken6x6 View Post
so the fuel pump had to be ordered, will be in tomorrow.
as i was cleaning 25 years of dirt off of it i notice one of the bolts from the frame going into the axle shaft had snapped off. i tried to get a drill in there but cant with the axle in. so it looks like ill be pulling the rear out. another bump in the road.
Ken
You can remove the rear cover and pop the c clip off then slide the axle out with out removing the whole rear. May as well change the axle seals while you are in the area. Ask me how I know.
Old 04-28-2013, 07:46 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
^^ i might just try that, and yes ill be changing any seals that get disturbed. hopefully i can get enough push on the drill to get thru that grade 8 bolt.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 04-28-2013, 08:02 PM
ken6x6's Avatar
i just found a few posts on the same issue, some seem to have put in a longer bolt with a nut on the inside of the rear. is this a better fix? or should i re-tap the threads and put it back to original?
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 04-28-2013, 09:11 PM
Ken
If the bolt is broken the threads in the case are probably still good. Most of the time the threads strip in the alum case and then you need to pull it out and do something to deal with the issue. If you have any questions shoot me a PM with your phone # and I'll give you a call.
Old 04-28-2013, 10:53 PM
ken6x6's Avatar
^^^ thanks ill keep you in mind.
yes the bolt is broken, hopefully i can get it out with out destroying the threads/case.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 04-28-2013, 11:04 PM
Ken
Post a pic of the problem bolt if you can.
Sam
Old 04-28-2013, 11:14 PM
ken6x6's Avatar
there she be...
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 04-29-2013, 12:21 AM
red56turbo's Avatar
Nice 1772! I love mine. You can get the fuel pumps at Napa. Good pumps and half the price last time I checked...........
Josh
Diesel Cub Cadets...........
Old 04-29-2013, 02:30 AM
Congrats on your Super Smoker!
