Is the pulley on the #2 cast as well as that of the #1. I would not use any other than cast.
Wig, as Matt said the inner part of the pulley is cast with the outer part being stamped steel and riveted to this. I have checked all the parts books I have available and this is the way they come from the factory. The shaft diameter is 3/4" on all of the gear boxes. I would consider trading if this works for you. thanks john
Did some research on the pulley of a #2 and it has the same part # as the one on a #1. ( for a 1/2 " belt) Is that true? I found that on Cub Cadet factory parts website.
Wig & others...There's a #2 tiller and there's a #2B tiller. The only difference is that bottom pulley on the 90* gear box. The #2B tiller has the pulley requiring the "B" Section belt and was for use on the 82 Series and later Model Cub Cadets.. The #2 tiller uses the same pulley as the #1 and 1A tillers.... It's all in CPE-2.... Ya gotta have those manuals guys...
Myron B |
Can you tell me where to obtain CPE-2 manuals. WEhat does CPE-2 stand for? Are they on the web or paper manuals I would have to buy? The #2 was the only 2 series tiller on Cub Cadet. com parts that is why I figured the pulleys were the same.
Wig, check on this site under "technical library"
MattG, you don't think a billet aluminum pulley is strong? They've been using them on racecars for years. Ofcourse like I said, finding one with set screws is another issue. wig, your shaft must be rusted, or a setscrew still tight....the pulleys should just fit snug enough that you can slide it off and on by hand....with the set screws loose.
Fly Fishing is not a sport...It's a way of life. |
Not for this application. There is a pretty big difference between accessories on a race car engine that consume no more than a couple horsespower driven by a 3/8" belt without too much tension and not much overhanging load, and a tiller that will use ALL of the tractor's 10-20 hp (depending on model) with a 1/2" or 5/8" belt that is many times tighter and further away from the end of the shaft. Cast iron is much stronger than aluminum. Additionally, never use an aluminum pulley on a snowthrower, either, for the same reasons. They can break and injure someone.
WIG... FYI: CPE = Consumer Products Equipment (parts manuals.)
CPE-1 is the IH Parts Manual for power washers, trimmers, & portable heaters, etc. CPE-2 is the IH Parts Manual for Cub Cadet Equipment like snow blades, mower decks, tillers, etc. The CPE-2 manual can be obtained from www.binderbooks.com and probably both if interested. Myron B CCSupplyRoom |
I have seen a picture somewhere of a noncast pulley being used on a thrower and the results wasn't pretty
Wig if you don't make a trade with johnk i know where you can get the exact pulley you need but it is pricey
