Old 12-09-2009, 11:37 AM
Stitch's Avatar
Stitch Stitch is offline
I may take the thing off, just to prevent dents getting kicked in the hood of my tractor in the future.
Killin deers and drinkin beers
Old 12-09-2009, 10:22 PM
Cvans's Avatar
Cvans Cvans is offline
I would think twice about removing the valve. There is nothing like going out to use the tractor and finding 2 gallons of gasoline on the floor. If you keep yours in an attached garage it could be a lot more than just your pride that gets damged. Hot water heaters and furnaces don't combine well with gas fumes. On the other hand I guess I have had valves that leak also. So now what's a fella supppose to do. I know, park in the neighbors garage!
Take care,
Chris
Old 12-10-2009, 11:27 AM
klejeune's Avatar
klejeune klejeune is offline
Or finding out the float stuck and filled the crankcase with fuel and after you run it the engine locks up. These are simple machines and need to be dealt with by simple means.
If your shutoff leaks, take it apart and place 2 1/8" o-rings on the stem of the shutoff and put back together. Works like a charm.
I like pie
