![]() Quote:
![]() I'll try to see if I can get an action pic. I have purposely let the lawn grow a little long to give it a proper test! I'm going to try to take a few pictures of the swap process too. It seems pretty basic, but there appears to be little information on "the 'net" about how to go about it. |
Where did you find the pulley.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10: ![]() |
IHCCW and CC Specialties both have them. IH-126393-C1
Our sponsor vendors may as well. |
Finally got it done today!
Here's the "How-To" 1. The tools you will need: *1 1/16" Socket and some method of turning it (I used my 3/4" ratchet since I don't have that size in 1/2 for my impact) *3 Jaw Puller and method of turning it. (2 jaw would probably work OK too. I prefer 3 because it is less likely to bend up your old pulley coming off.) *Junk 3/8 socket from your China tool collection, to put over the grease zerk on the spindle *Some sort of penatrating oil (I didn't notice that was actually chain lube until I took the picture.. Oh well. It worked!) *Anti-Sieze *Chunk of 2x4 (I couldn't find a nice beat up and greasy one, so I had to use my "Sunday only" 2x4) *(oh... and a 1/2" wrench/socket if you have to take your belt cover off... I leave mine off) 2. My 44A with the old pulley still installed and the new pulley laying on it. 3. A better shot of the two pulleys. There's a pretty clear difference between them. If you're unsure of which pulley your deck has, the "speed-up" pulley is the same size one both cogs, the "slow" pulley is not. It's that easy to tell! 4. Flip the deck over and stick your chunk of 2x4 between the center blade and the sheet metal lip. Make sure to leave your pulley belt on during this step because you can keep tension on the wood and keep it from falling out while turning the deck over just by grabbing anywhere along the belt. 5. Flipped over and my 1 1/16" Socket ready to go! 6. Nut came off nice and smooth... Was on with maybe 50 Ft-Lbs torque? Flood with spray oil to help pull slip off. 7/8/9. My 3 jaw puller (which used to be somewhat hard to find, mine is a Craftsman), my junk 3/8" China socket on top of the spindle (3/8" is the one that just wanted to sit there the nicest... happens to be 1/4" drive, though I doubt it matters), and the entire assembly ready for some torque! I chose to put the ears of the puller on the bottom of the first pulley. They didn't seem to want to slip around or anything and it worked well! 10/11. Popped right off with no drama. The old pulley did get bent up a bit, but nothing that can't be fixed. 12/13/14. Cleaned up the top of the spindle and the treads, then anti-seized the snot out of it. IMHO, you can't use too much anti-seize. Maybe next time I won't need the puller? 15/16/17. Pulley slipped right back on, tightened nut down to ~50FT-Lbs, put the belt back on and ready to work! 18. Deck back on the 149 and ready to MOW! (Sorry about the finger in the pic... I took that one with my phone since the real camera got put away w/the tools). Also, I don't normally roll grill-less.. ![]() 18a. No picture here, but I was able to use the belt that was on the tractor already, thought it is at the very end of its adjustment. Impressions: EXCELLENT INVESTMENT. I took a video with my phone, but it really doesn't show you much so I'm not going to bother. Essentially, the thing just cuts way better now. The blades still do not seem to turn as fast as newer mowers, but they are clearly quicker and the difference while cutting is very apparent. I'm so happy with it I'm considering having an OVERDRIVE pulley made (3"?) to really get the blades singing! Anyhow, if you think you want this upgrade, you DO! Makes a big difference! ![]() |
Nice work and thanks for the pics.
looks good, nice write up too.
are you able to mow at the same speed as the bigger pulley?
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
Pardon me for asking but what is a speed up pulley (I have a 1200 w 44a)?
Thanks for the wright-up.
I would think extra care is required for flying rocks and debris. I wonder if that and ?gator blades? would work with a regular bagger. I like the nutrients from the clippings to go back into the soil but I'd like to get a bagger for when I need to cut some very high grass. Good job.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights 72, Serial #231093, K161S Serial #C281773, 36" deck 149 & Original Yard art 1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch 1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted 123 FEL and weight box 10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller |
![]() Quote:
(In other words, the government said "Make the blades turn slow!") The slow speed kills the quality of cut. If you "speed up" the blades, OHHHHHHHH,,,,, you get a NICE mow cut!! ![]() In the 1950's, my next door neighbor had a 28" cut push mower with the blade directly connected to the BIG vertical shaft engine. The large diameter of the blade made the tip speed VERY high. It could launch a BIG rock 100 feet easily. The machines were in the news constantly for the damage they could do. It could throw a piece of wire like a bullet. Lots of people had lost spoons and forks stuck into the sides of their home. ![]() |
![]() Quote:
The 44a deck on my 109 has the speed-up pulley and does a great job. Even though the 10 hp engine is tired, it still has plenty of power to run the deck with this set-up.
IH Cub Cadet 109 IH Cub Cadet 126 (2) IH Cub Cadet 149 IH Cub Cadet 1650 MTD Cub Cadet LTX1042 |
