Old 06-16-2013, 08:41 AM
105_Tom's Avatar
105_Tom 105_Tom is offline
clean up or replace the points, gap to .0020, and put a new condenser in it. a faulty condenser can lead to the problems you are having - backfiring, poor performance/won't carry a load, etc... easy enough to do before you tear into the engine.
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Jumper Jumper is offline
That's actually not what ray was talking about. He is referring to the split intake manifold. The two halves will leak.
Woops, I should read it a little closer, sorry Ray, but like on this carb the lower gasket is partially missing causing the same effect (air leaks) as what Ray described............ ok ?
