Old 06-09-2013, 10:16 AM
Jumper
Fix the forks first then if you need something on the front take a look at what Grampie makes, think also has them so you can hang suitcase weights on them
http://www.onlycubcadets.net/forum/s...ad.php?t=24823
This is what CADplans did for his weight bar.
http://www.onlycubcadets.net/forum/s...ad.php?t=25238
Old 06-10-2013, 12:52 AM
Originally Posted by Jumper View Post
vartz04: That looks like a good design, while your at it could you come up with a good design for hanging weight off the front too? I picked a six bag skid of top soil (at 40 pounds each) and thank goodness I had steering brakes on the 982 ! The reason it does not look like it lifted the skid very high in the picture is because the front wheels are dangling a foot in the air. I need to get some weight for the front.
Moving past the problems with the length (which really doesn't seem that excessive), the square tube construction of your setup is far more rigid than angle of even 3 times the thickness.
I dramatically prefer the design of what you have vs. angle. Just sort out a way to shorten up the linkage, and it should be great! The easier way to go would be to add some suitcase weights to the front end, like you suggested. Filled front tires might even get it done.
Old 06-10-2013, 08:17 AM
Jumper Jumper is offline
Thanks for the help guy's, the forks are a Swisher product for a four wheeler and my first thought was to modify it for my loader to move pallets and this was just a after thought. I had the loader on the tractor at the time and never had a front traction issue but I don't always have the loader on. These worked out for quick attach on the 3 point and carrying small stuff around. That's the reason why I thought a front quick attach weight idea would be cool.
Old 07-19-2013, 11:29 AM
dieselman1 dieselman1 is offline
Did you ever make your sleeve hitch fork?
