Old 06-17-2013, 02:38 PM
cub1440 cub1440 is offline
I did pull the yellow wire off of the M, key switch and also from the side of the motor where it attaches to the wire from the armatures. I was told it was a Kill wire for the motor. It still has no spark or fire. Im in the process of looking at all the wires again to make sure nothing is crossed. Im certian it doesnt take any wire to make a spark, just the stator, armatures and starter. I think I have something hooked up wrong..looking at my wires
Old 06-17-2013, 02:59 PM
Sounds like you have a bad Magneto(s).
The Stator is for "charging". The "starter" is for rolling the engine over. I am not clear on what you mean by armature. However, none of these three items have anything to do with the "spark".
Old 06-17-2013, 03:27 PM
Im not sure bedell. This is the third(second one I broke) one I bought from briggs. It just has 4 bolts and two yellow wires that has a connection already on it that plugs into my votage reg. Im almost done tracing all the wires and bout to hook them back up. I didnt find anything wrong.
Where does the wire from the armature go? is it a ground or hot?
Does it connect to the yellow wire thats already ran and connected to the housing?
Old 06-17-2013, 04:51 PM
Originally Posted by cub1440 View Post
Hey thanks to all for the above info. I have looked at the diagram that was sent to me and traced every wire after removing the engine for the 3rd time off frame. I rechecked everything twice and covered all the wires back up and placed the motor back in and well, I still have no fire. Im so lost on why its not working. Motor runs fine or well did before I decided to replace the stator and armaters.
I did find the wire on the armatures was bad so I replaced it. That is a ground wire or at least I hope since I hooked it up back where it was with the yellow wire(kill wire) as im reading. Any other help or ideas?
Did you replace the wire between the two armatures with a homemade wire? That is the kill wire and it has a diode in it. It’s number 5 in the pic. Part number 493792 WIRE ASSEMBLY
Briggs calls the Mags Armatures, don't ask me why.
Old 06-17-2013, 05:02 PM
Yes I did replace it with a homemade wire. I didnt see no diode in it since it was all broken in pieces and chewed up from the flywheel.
Old 06-17-2013, 05:13 PM
My guess is if you remove your wire it will start and as long as you have the fuel shutdown solenoid wired correctly it will shut off but it will take a few seconds to shut off. You will need the proper wire harness from Briggs in order for it to function properly.
Old 06-17-2013, 05:36 PM
Just sent you a pic to your e-mail showing how a Vanguard is wired.
Old 06-17-2013, 06:53 PM
Sam Mac you was right. I cut the wire that I made and it started but only was running on one cylender. Im in the process of ordering a new wire as we speak. Its been an agravating week but at least its running.
Thanks for the Vanguard Diagram, I will definetly use it. Im thinking of restoring this whole machine this winter. Its a great mower and thanks for everyones help.
Old 06-17-2013, 07:18 PM
It should run on both cylinders with your wire removed. You may have cooked one of the Mags they way you had it hooked up. See if you have spark on both plugs.
I am going to move this thread to the MTD CCC area since this is turning into more of the how do I fix this type of deal.
Old 06-17-2013, 10:00 PM
I had the same issue with my Vaguard. There is a diode in each wire that goes to each mag. Go to Radio-shack and get 2 $2 diodes and put them in each kill wire. The ones I picked up are rated at 1000 volts @ 1.5 amps. The new harness that came with my mags didn't have them in either. The diode keeps them from grounding each other out.
