Very cool idea, I will have to give this a try as well. Might make a disk kinda like a stump jumper on a bush hog and attach 4 to it. Being round it would have even less impact when hitting the ground. Also could make the lines a bit shorter. Is the line precut to length or come in roles like a regular weed eater?
now if only you could make a front attach deck that flips up and makes it easier to change the string. Also, how does the outer nut stay on the string?
Gary '49 Farmall Cub, '62 "Original, '70 73 w/402-D Haban sickle, '71 127 w/38" cast end deck, '73 149, '76 Sof76, '07 LT1045 w/bagger, '09 GT2544 w/bunch of mods. 5 Exmarks, Kubota B2920, blah, blah, blah... |
Hi GC : I just lift the lawn mower up with the boom pole on the big tractor,but so for I have not had to change the line,
and the outer nut is weld on also, |
I'd love to see a photo of the freshly cut back lot. I've got the same situation and using an old 44a mower with the trimmer string would be a great option.
Welding up my version of this tonight. Wondering if the distance between the nuts is critical as well as the length of the string in operations. Won't have pics up until next week. But hope to have this up on a 44A and mowed down a blade or two of grass on a couple acres. If this works well I have a rusty deck that was meant for just this. Open up the front of the deck and go...
great idea, im sure the light weight string frees up some HP.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
I put the 1/8 line on my straight shaft trimmer kinda like that but it wears down or breaks after 20 min , but I am ging thru knee high weeds and vines too.
Very cool idea !!!
Does the string throw the grass out the side of the deck ??? I have never had to buy trimmer string of that size , is there a better brand to get and i guess you can get the trimmer string about anywhere ??? |
I use .155 th trimer line and got it at Lowe's |
