Old 06-29-2013, 07:57 PM
cubs-n-bxrs's Avatar
Did a little bird dogging and I found the pin that moves the speed control cam is almost worn through on the bottom side. When the lever is moved forward the cam speed plate rides on the unworn portion of the pin then drops into the worn groove and that is were I'm getting the added speed. Looks like we will be doing a tear down sometime in the near future. Break out the mig welder fill the worn area in and grind back smooth. Should be good for another 30 years.
Old 06-29-2013, 08:09 PM
I like those big dollar repairs! Way to go buddy, let us know if that fixed it. Oh and let's have some pics.
Old 06-29-2013, 11:16 PM
Good deal!! Like I've said before, most of the problems with these hydro's is just in the linkage!!
Old 07-11-2013, 07:46 PM
Well the old girl is going back together. Let you guys know tomorrow night how she works. Sam sorry about the lack of pics I'm just a slacker at heart ya know. I found 3 major problems with the hydro. 1 The pin that runs the cam plate was almost worn through. 2 The hole on the cam plate was worn so bad I could almost pull it off of the trunnion springs and pins. 3 One of the trunnion spring pin heads was broken in half.Thank ful for having an adequite supply of spare parts. Got to adjust neutral position and put the sheet metal back on and we are ready for a road test. In the process of fixing all this business I repaired 4 spare hydro dump valves. All know leakers. Checked them out on the 1572 and all 4 worked flawless.
