Low battery voltage? Bad battery or charging system malfunction as noted above. |
2.) This picture shows the voltage reg/rec. It's #20 in the pic. (Click on the word "this" it will take you to the page on parts tree.) 1641.jpg I have no idea what the thing is you are describing in #2..... The regulator/ rectifier needs to have a good base ground. Look here, Roland has a nice diagram that will help. This is not for your model of cadet, but the system works the same way. The wiring may be different, but I doubt it. Check the reg for B+ on one of the terminals key on, engine off. If it has battery voltage, your good. Start the engine and check the same wire again, should have 13.6V-14.6V on it. If not, OHM the stator. (Use Rolands specs, should be close enough.) If ok, replace the V. Reg. If the B+ wire on the V. Reg is putting out 13.6V-14.6V, then your issue is in the wiring. Start tracing.
Great success!
I went back and checked those items, voltages were close to spec. Started tracing again and decided to give every contact, ground, and coupling a really thorough clean (talking toothpicks and qtips). Fire it back up, PTO engages, no amp light, 13.48v at the battery at WOT. There might still be an issue with the charging system, but for now I can at least mow again. There might still be some grime I missed behind the dashboard too? I'm not the original owner and this machine was somewhat neglected in the previous life. To echo the sentiment from another thread, you guys rock. Thank you so much for all the coaching, and suffering my noobie questions
Like Sam Mac said, the charging system on these are a little on the weak side. 13.4 is close enough. Great news!
