Old 07-04-2013, 11:32 AM
Originally Posted by bocephus1991 View Post
Cold natured is one thing,taking longer than three minutes to start is another
Originally Posted by Mike McKown View Post
If your engine is taking 3 minutes of cranking to start, you have a mechanical/electrical problem and that's what you should concentrate on rather than some miracle in a can or bottle.
You said "hard to start".... I didn't realize you meant THAT hard to start! ...... Buddy you are missing something, there is definitely a mechanical issue somewhere...
Old 07-04-2013, 01:54 PM
I use "cheapo" 87 and it works fine. In the winter I put in higher.
Old 07-04-2013, 03:18 PM
cuber cuber is offline
I add a splash of SEA FOAM to all of my gas. Love the stuff!!!!!!! The only bad thing is that it cost $45.00 a gallon when it's on sale.
Old 07-04-2013, 03:26 PM
cubby102's Avatar
cubby102 cubby102 is offline
I run 89 in the summer and 93 when it drops below freezing. My cubs seem to like it all of them from k161 to the kt17 would run better on 93 when freezing
Old 07-04-2013, 06:17 PM
Merk Merk is offline
There are lot's of myths floating around. Much easier to perpetrate these stories on the public in internet chat rooms.
We have had E 10 in this area for 25+ years. ALL my small engines have run and run well on it. I have seen no deterioration of rubber parts other than what was normal with straight gasoline. Still have old tractors that have the original fuel hoses, needles/seats, etc. on them. The only carbs I have seen gummed up was BEFORE I found out that the ethanol really likes to attract water. The sealed cans fixed that problem. Carbs that run on straight gasoline will gum up also. They'll also dry out and get full of a white powder caused by corrosion and this is nothing new. Been going on since there's been carburetors.
Ethanol does a very good job of keeping your fuel system clean, ONCE IT IS CLEAN. If it's dirty, it's first doses of ethanol can/will scrub the dirt off and may cause problems.
Octane boosters bought off the shelf in parts house will raise octane a very insignificant amount. But so will kerosene. Check contents of the bottle and see what you're actually getting.
Higher octane fuel puts out no more power than regular if your engine is tuned to run on regular. 93 is also no more volatile than 87 so there is no advantage in starting the engine.
Of course, you could just have a tank of contaminated or really old fuel.
In addition to Mike Mc Kown comments you need to go to a 30 day gas rule. Any gas (2 and 4 cycle gas) that is over 30 days old is added to my truck and replace with fresh gas. Add a fuel stabilizer before you fill your container(s). 2 good ones are Sta-Bil and the one Briggs and Stratton sells. I have never had any good luck with sea foam......tried it several times and engine is low on power or dies. Replace gas with sea foam in it and small engines runs like it did before sea foam gas.
Along with the 30 day rule I used a container that is sealable and put the container on a piece of wood because the cement floor is usually colder than the temp in my shop.
The Kohler service manual says to run engines on 87 octane fuel. It is ok to run up to 10% alcohol in fuel system. Running higher octane in an engine designed to run lower octane will cause carbon deposits. I actually notice poorer performace on 92-92 octane fuel at plow day(s).
I have been running gas with 10% ethanol for 9 to 10 years with no problems. One of my Kohlers has .01 off the top of the block and .04 off the head on 87 octane with 10% with no spark knocks.
Project Uncle Dick
Cub Cadet 70
