I wasn't sure which was the newer deck. I assumed the stamped spindle housings were newer but don't know if they're original to the deck.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
I worked on the deck today and got the new corner piece made and welded in. I put on the extension piece and realized it was about 3/4" away from the back side of the deck so I cut a wedge piece out of the top and bent it forward and I'll weld it back together. I think I'll weld a piece of tubing along the bottom front edge of the deck flush with the bottom to keep the front of the deck from getting bent up. I had to beat on it with my BFH to get it somewhat straight. I need to check for front tire clearance first to make sure the tires won't rub the tubing when I turn with the deck raised.
Looks good Adam!
Lookin' good- those are always the troublesome spots on the 48"ers.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Nice work, as always, Adam!
I got the discharge extension welded as well as patched a section around one of the center casting bolt holes. I mounted the deck on the 129 to check for tire clearance at the front of the deck. There's plenty of room to add a reinforcement to the bottom front of the deck. That should keep it from getting bent up like it was before. I need to buy the spherical gauge wheels so I can start making mounts for them. I plan on running the mounts front to back like the newer 54" & 60" GT decks are. Then the mounts shouldn't tear loose from the deck over time.
Looking great! I got some 5" spherical wheels from a seller on Amazon because no one had any local and they had them the cheapest. They've been on my 48" for about a month give or take, which is about 4-5 45 min. mowing sessions and they have held up well and don't tear up my lawn.
That is nice, Adam!
Adam, that looks like some mighty fine welding and fab work.
I got a couple more you could practice on
Cheers, Rick
Thanks guys.
Today, I picked up some 1/2" black pipe and cut some pieces to weld to the bottom edges of the deck to reinforce it. I decided to add a piece along the back too to help add reinforcement for the gauge wheel mounts and to make it match the front. I introduced the deck to my sledge hammer and gave it a little "attitude adjustment" to get the front side back in line. It is now straight and ready to weld the pipe on. ![]() ![]()
