Old 07-07-2013, 08:43 PM
Plowboy1086's Avatar
Plowboy1086 Plowboy1086 is offline
I got mine board out but it was the junk briggs aluminum block so it did it again. Got a kohler in it now
Bi-Polar Plowboy Plowboy X Press
Old 07-07-2013, 10:11 PM
sandreassi's Avatar
sandreassi sandreassi is offline
What are some options he has for used engines that will work in this model?
Old 07-08-2013, 10:28 AM
Originally Posted by sandreassi View Post
The last few posts make me think his engine is on its way out. Is this in need of a rebuild or something less?
Thanks for all if the help, as always.
If either one of the head gaskets are blown and the path is through the pushrod area of the cylinder, the compression can pressurize the crankcase and push oil out.
It's easy enough to check. Just put air pressure in the spark plug hole with both valves closed and then listen.
Old 07-08-2013, 11:09 AM
That's a really good idea.
