Mike
If it was me I'd put a gauge on the line going to the lift cylinder and see what you have for pressure. Could be a bad seal inside the cylinder, the rock shaft could be seized up the spool valve could be bad the relief valve on the pump could be bad. You are going to need to do some testing. Don't want to see you replacing part after part for nothing.
Sounds like, that you still have "floaters" traveling through the system.
I would suggest that your check your Charge Pump and Implement Relief Valves, Items #2 & #4 in the Ported Pump Image diagram to see if they are clean and operational.
Thanks, Sam & Roland
I read through the manual from the technical section and pulled the relief valve and check valves. They all looked beautiful, like new. The problem turned out to be the button on one of the check valves was stuck. I worked it loose and put it all back together and everything works once again. On the plus side, I know everything looks good inside and it has brand new clean fluid and filter X2! I really appreciate the help & support from this forum. I've met the nicest folks here. -- Mike |
Mike
Just my 2 cents but I have had my valves rebuilt by this guy and have been totally happy. Machtech Direct 605 Furnace Rd. Conneaut Ohio 44030 Phone: 440-499-5813 Email: mark.machtech@gmail.com E-Bay add $35.00 each plus $4.95 shipping ($4.95 flat rate regardless of amount) That's both valves rebuilt for only $74.95
