Old 08-10-2013, 08:55 PM
johncub7172's Avatar
Cool..
Why didn't you remove the blade to make it easier?
What makes you think it is easier?
Old 08-10-2013, 08:57 PM
MrGitrdone41's Avatar
Good job on the axle John!
1988 1812,dual ports
1973 108
1968 125
Old 08-10-2013, 09:03 PM
I was able to start the axel in the c-channel of the frame going in at the top. Used a rubber hammer and hit upon the cast iron axel, driving inward the axel home. Being careful not to swing and hit foolishly, came to a certain point where I had to change gears a bit.
A 4x4 block of wood, and a 6# hammer got the axel in motion.
The holes begin to align.
With tension now squeezing the gap closed, I have a measurement of 3.094". Note the bolt bending, I did not have a better bolt. When I released the tension on the gap, I have a new gap measurement of 3.225".
May I ask why you just didn't squeeze to just under 3.310? ( 3.300 would have worked and been much easier to get the axle back in )
Old 08-10-2013, 09:06 PM
Thumbs up
Thanks Sam!
Old 08-10-2013, 09:12 PM
Nice work, John!
Old 08-10-2013, 09:18 PM
What happened the first two times I had tightened the squeeze bolt, the gap opened back up to 3.343, and 3.340 respectably. All that I can say is that on the third time I tried to set the gap closer, I over tightened the squeeze bolt. Having done that, I thought I would try to force the axel in position, rather re-open the gap. I was however, having difficult time getting a better gap set point as you mentioned 3.330" .
Old 08-10-2013, 09:20 PM
Nice work, John!
Thank you Allen! {raise my coffee cup!}:
Old 08-10-2013, 09:22 PM
cubfixer's Avatar
cubfixer cubfixer is offline
Nice pics and interesting thread!
John
There's times at work after machining a casting it'll close up or spring open. I usually spread/squeeze the part, measure and see where it springs to. Then make an adjustment on how far I go.
And yes,sometimes even the most carefully designed plan doesn't work and it goes too far
