Old 08-15-2013, 10:14 AM
red56turbo's Avatar
Gary,
The bracket should mount to the block right behind the big pulley on the crank IIRC. Don't have any pics handy. Got rid of all my single cylinder cubs...........
Josh
Diesel Cub Cadets...........
Old 08-15-2013, 11:02 AM
Yep that is how it mounts, you have remove the pto and the pto basket to bolt it back on, unless the bolt broke off in the block,It should be any easy fix.
Up to 534 and counting...
Old 08-15-2013, 11:37 AM
sawdustdad's Avatar
This should help
Old 08-15-2013, 01:39 PM
red56turbo's Avatar
Originally Posted by sawdustdad View Post
This should help
Chaching!
Josh
Old 08-15-2013, 04:10 PM
sgirdham's Avatar
sgirdham sgirdham is offline
The bracket is backwards, flip it and it will bolt to the block and the opposite side of the ear on the s/g.
1981 IH Built 782- 44" deck
1650 dual stick
71 "121" round fender and replacement k301 carlisle tru powers and v61
Old 08-15-2013, 04:48 PM
gcbailey's Avatar
gcbailey gcbailey is offline
OK... I see the hole, so the muffler is definitely going to have to come off. Apparently it's been this way some time too...
Gary
Old 08-15-2013, 11:36 PM
sawdustdad's Avatar
Unfortunately, it's not just the muffler. PTO and clutch basket/pulley need to come off to get the bolt in the hole.
Old 08-16-2013, 08:54 AM
PaulS's Avatar
PaulS PaulS is offline
Sawdust beat me to it. I have a 102 engine (K241) that my son and I are restoring and the bolt is just long enough that it hits the pulley before it is out of the hole so that arm stayed on the engine and gets painted with the engine.
Old 09-08-2013, 08:57 AM
gcbailey's Avatar
Just now getting a chance to get back on this.... So... how big of a job is it going to be to get the PTO off and the basket pulley?
Gary
Old 09-08-2013, 12:15 PM
red56turbo's Avatar
Gary,
The set screws can be a PITA. The best thing to do is hit em with a good penetrating oil such as PB Blaster. There are actually six of them. They are located in three different holes. You take out the first three and there are another three under the first three (make sense?). They are allen head set screws. The bearing also has a locking collar on the crank. Time and patience and it'll come off. I've had some fall off, but others took an act of god.........
Josh
