How big is the pulley you have? a bigger pulley on the deck will make it go slower.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
I have the small pulley, I think you have the big pulley. I'll measure it for you tomorrow, but this is what it looks like.
Measured the pulleys , the late style is 6-1/2” OD and the belt in the pulley would have an effective OD of 6”. The early style is 5-7/8” OD and the belt in the pulley would have an effective OD of 5”. My tractor has approximately 5” pulleys on the mule drive and the belt is a NAPA 5L980W that crosses to a B95
well sounds like I have the right pulleys then. thanks for measuring yours. Will have to see how the 92" belt works, or try the 94 one from tractor supply
All this talk about pulleys ??? If u have an early 1782 and from your pics looks like u do, it calls for cub cadet belt # 954-3023. I went out to my NOS supply safe and got a new factory belt and ran a string around the back and it measures 93 inches.I hope this helps. Dave
went and got a 94 inch belt from tractor supply, and it seems to be working a little better. the one from oreillys was slightly narrower I think. its still not perfect, but I think the motor mounts are a little soft, and letting the motor sit a little bit lower. the oil pan seems to be be about resting on the crossmember, so maybe new mounts will solve that.
