ok thanks
does anyone know how to compress the spring on the clutch in a vise, im trying to reinstall my teaser spring and throwout bearing, how do i compress it , do i tap the shaft, if so how
guys, i built a homemade clutch press out of 2 thick pieces of angle iron, threaded rod, and 4 washers, and nuts , i had to drill a hole to fit the bearing with a 1 1/'8 hole saw it took awile, pics soon
Sounds cool. Would like to see some pics. I put my clutch shaft in the vice vertically and used a series of two vice grips and a pry bar and used one set of vice grips to pull down on the shaft and the other set to lock it in place as well as the vice jaws. Tricky but I got it and it was enough to release enough spring pressure to remove pins
heres the clutch i pressed, i had to replace the teaser spring, the throwout bearing , and cleaned up the shaft and the pressure plates, now it needs a good disk
heres my homemade press
it works good
Good work. Can you show how it works, with the clutch, etc. in it?
Cub Cadet 86 Mahindra eMax 22 w/FEL Husqvarna LGT2554 John Deere GT275 '48 Ford 8N '41 Ford 9N Yerf Dog Scout CUV |
thanks, you just slide the angle iron on to each side the shaft , and run the threaded rod thru and tighten it
heres the press on the clutch
