Old 09-17-2013, 07:37 AM
yea i agree, i also should watch wheel weights on the axels although they were ok, i will change the weights around too
Old 09-17-2013, 05:23 PM
so how do i gear this thing down, will a creeper gear prevent it from losing power, or do i need a bigger engine
Old 09-17-2013, 05:43 PM
austin8214's Avatar
What are the rules for the class you pull in? Without knowing the rules it's hard for us to help you.
Old 09-17-2013, 07:01 PM
only rule is you need wheelie bars, we pull a dead sled with concrete blocks up to almost 4000lbs
Old 09-17-2013, 08:52 PM
austin8214's Avatar
So there is no rules in regards to engine hp or size.
Old 09-18-2013, 02:57 AM
cubby102's Avatar
cubby102 cubby102 is offline
Cheapeast easiest way to gear it down is put a shorter tire on it.... and don't use a creeper for two reason. One being itd be a major weak point as they were designed to just slow it down. Two being it makes your third gear slower then your current first gear.
Old 09-18-2013, 06:34 AM
I have never seen one with smaller back tires I would need other rims and alot of people use creepers for pulling in our club and u have to have a garden tractor so I'm assuming u can't have too much horse power but alot of them are 10 12hp one is 14 and one is a 1606 cub cadet but I don't know what engine I think I will just get a fine spline carrier and axels but do I need to measure the teeth on it to install it
Old 09-18-2013, 07:27 AM
Mainecubcadet108's Avatar
Mainecubcadet108 Mainecubcadet108 is offline
Just remember if you get a 2 piece fine spline carrier you have to change ring gears.The one in a 2 piece is straight cut and the one in your cub now is curved cut.
Current tractor my son and i have
1991 wheelhorse 520h 60"deck 48"snow blower w/ onan 20 hp
1980 whelhorse b-82 need restore
1976 simplicity 7116 all restored waiting for a new motor (my sons tractor)
1967 sears super 12 (my sons tractor)
1972 Cub cadet 108 restored w/ complete motor rebuild 5 years ago
Old 09-18-2013, 02:46 PM
do i need a cast iron ring gear
Old 09-18-2013, 05:20 PM
Use the ring gear off the carrier that broke if its still good.If not you need to find one like the one that came out of the carrier that broke.
