Old 09-18-2013, 07:23 PM
Originally Posted by Shaner View Post
So if I'm reading this right....all I have to do is installed the key switch for the magnum engine in the cub and that's it? I thought there was more to it if I remember. RBedel do you happen to have a handy wiring diagram for the relay conversion?
No, that is not it. There is more.
The KT needed batter + to the coil to run, then kill the power to it to shut off.
The mag, only needed to have the magneto grounded to kill it. No power required to run.
The relay kit is as simple as using the existing old power wire that ran to the coil to operate a relay. When the relay is powered, it opens the contacts. When you shut off the key, it grounds the mag and shuts down the engine.
Old 09-19-2013, 09:24 AM
mickb72 mickb72 is offline
Default cub
Hello, and don't forget those diodes in the kill wire to protect from stray voltage. I need to add some to a couple of mine, i think thats good protection. Mike
Old 09-19-2013, 09:26 AM
Huh.... Explain
