Old 01-06-2014, 08:01 PM
johncub7172's Avatar
Guys
I need some advice on painting. The last couple days I started to paint the fenders for a 1641. I wet sanded the powder coat, primed it with Rustolium rusty metal primer and sprayed it with Valspar Cub Yellow. No problems so far. This AM when I got it in better light I noticed that I had a couple areas that needed another coat for good coverage so I started to spray another coat, this is when it went bad. The paint started to wrinkle. I stopped and let it sit, later in the day I wet sanded the whole thing. Now do I need to re prime it or can I just hit it again with the Yellow? Thanks in advance.
Sam
Sam, Glad it turned out! I just wanted to add, that yellow is by far, the worst color to cover,....it flat out sucks. I think what might have happened was the paint "lifted". On most parts, by the time I finish one coat, I'm right back on the previous part with another coat until the yellow has covered. I had to sand out the wrinkles when it happened to me. I would not have concerned myself unless bare metal was showing after sanding, or to build back up the sanded area, would I have used a primer. Temperature differences can cause wrinkle problems too.
Old 01-08-2014, 10:36 AM
Originally Posted by mjsoldcub View Post
maybe this thread is dead, but i was just reading, and if anybody wondering; often times most enamels will have a minimum re-coating time..say " do not recoat for 48-72hrs" if last coat has dried for a certain period of time. it is exactly what you thought sam mac...this is called alagation or alligator..previous coat may not seem wet, and even dry, although uncured, and as the coat on top starts to cure, it reacts and shrinks..enamels take along time to cure as opposed to uerethanes, laquers and such...when working with enamels i tend to do all my top coating in one day...im no expert, but have been "squirting" for about 15yrs..if this helps at all.
Thanks guys.
In the future I'll do all the yellow at one time, and ditto on yellow not covering.
Old 01-08-2014, 10:57 AM
Leadslingingdaddy's Avatar
What was the temp in the shop?
Old 01-09-2014, 03:11 PM
no problem, you guys help me out all the time!! nice looking cub by the way!! came out good...
