Old 09-28-2013, 10:24 PM
Well...... it really sounds like you did everything correctly. Its hard to say what caused the failure. I understand your frustration though. We overhauled a motor last year, it didn't make it 200 miles and spun a rod. Tore it down and could not find any reason for the failure. Sent the block and the crank to my regrinder just to see if he could find anything that we didn't. He told me it was a perfect rebuild. We labeled the failure as "block contamination". Our assumption was there was metal or dirt that was stuck in an oil galley. I have overhauled/rebuilt over 100 engines in the last 15 years. It was the first one I ever had that failed. So, sometimes, even when you do everything right, something goes wrong. Tear your motor down, you may find that is was just a freak or even a part failure that had nothing to do with you.
Old 10-01-2013, 06:23 PM
machinehead323 machinehead323 is offline
well i got the engine out and opened up the bottom end first. rod is toast. all kinds of galled aluminum on the crank. as you can see in the pic the hole is twords the cam. the only think i can think of is that the nuts loosened up. i torqued them to kohlers spec for new posi-lock rods. when i got the crank and rod back from the machineshop the rod was installed on the crank. now im wondering if they torqued them there too and if i should have used the "used" torque value. they make it a point in the manual that says do not over torque, loosen and retorque the posi lock rods. im pretty sure my cylinder will need to be rebored to .030 now. there are lots of score marks where aluminum got onto the skirt and scored my walls. most are not bad but i think its more than a kiss from a hone will take out. there are quite a few that are below the crosshatch. i know kohler doesnt do a .020 under rod but i found one on the net http://shop.kustomlawnandgarden.com/...-NEW-ROD21.htm and there is one on ebay too. dont know about how good these rods are though, better than mine for sure. id hate to buy a rod just to put bearings in it.
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
Old 10-01-2013, 09:53 PM
bocephus1991's Avatar
OUCH! That sucks! Was the crank turned at the machine shop? Did they tighten them to much then loosen them then re-torque them? Was it hard to turn over before you started it? I wonder did they not turn the crank enough and it was to tight once the engine got hot? or maybe the rod was not machined correctly? I'd think if it was to loose it would have broke the rod not galled it?
Brian
Old 10-01-2013, 10:36 PM
austin8214's Avatar
I agree. I think it was over tightened.
Old 10-02-2013, 05:13 AM
did the shop assemble the shortblock? i would see if they will make good on it if they did
Old 10-02-2013, 09:37 AM
the machine shop ground the crank and bored the block. when i got the crank back the rod was attached to it. of course i took that off so i could reassemble everything. i do not know what they torqued to to at there shop. i torqued it to teh new measurements of the manual with a calibrated CDI torque wrench. a shop did not assemble the block, i did. so i will be making good on getting new parts. the assembly seemed to turn over nice.
Old 10-02-2013, 11:49 AM
cubs-n-bxrs's Avatar
I would use lubriplate assembly lube this time when you put it back together. I would also use a break in oil such as Brad Penn or an equivalent with a high zinc content. Just my 2cents.
Old 10-02-2013, 02:31 PM
samiam44 samiam44 is offline
Let me make a suggestion..
I would remove the aluminum from the rod journal with muric acid as I've read on this forum and then polish it well. You can go aftermarket or factory on rod. I would use factory and get someone to machine it for bearing inserts which are from a continental engine ~15 bucks for the inserts.
Aftermarket rod will work only with old style piston- not the Mahle.
I'd measure where the score marks really start- if they are only where the skirt runs, you can just hone it lightly. It's the area where the piston rings travel which is of concern and even there a few light scratches won't hurt.
Good luck!
Michael
Old 10-02-2013, 02:44 PM
The crank is beyond a polish job.... and the rod is now junk.
Old 10-02-2013, 08:41 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
lack of lubrication. sure you had the rod in correctly? or the cap flipped 180 ?. did you by chance plasti gauge the rod to the crank before assembly?
