Kostendorf...Did you have to widen or shorten the gap after you static timed it?
I had to shorten the gap. Setting it with the S in the window the points would not close. So I started there and began tapping them together until I got it run and then tried to fine tune that. I have always heard the matchbook cover setting would do it, and that's about where I am with mine. That was a touchy setting on this one. I can't tell you how much it shook and vibrated at throttle up when that was set wrong. But, all seems well now. I had a snap ring come off the shift/brake linkage a couple days back, and we went through the woods pretty fast until I got it shut down. Got that fixed and we are up and running again. Now I can't find my bracket that holds the muffler on. One thing though, without a muffler you can sure tell how smooth or not smooth is runs. Dave |
all I did was static time it. I did not move the points either way. It starts almost before I turn the key. No complaints there but it does seem to vibrate quite a bit. This is the only cub I've owned so I really don't know what normal is. I might try closing the gap a little and see what happens. I did put a point saver on from Dave Kirk. When you turn the engine by hand till the light comes on the s is right in the window too so I thought I've got it timed perfect.
Your not setting the timing correctly if you don't move the points with static timing, unless the points are perfectly set to begin with. What static timing does is get the points at the precise setting to begin opening when they are supposed too. This is the reason for the multimeter, to measure when the points actually break open. If they break open but the S is not centered, then you must either open or close the points and retry again until the S is centered at the exact moment the points begin to open, not be .024 open.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
That is how I did it with a multimeter. And when the points are fully open it checks .024 . I only checked the s again using the points saver light to see how close it was. And as I said on my first post I believe the rod opening and closing the points is wore maybe causing the wide gap in the points.
Are you sure you are looking through the correct hole?
Maybe not....it's right below the generator, little difficult to see, but visible with a flashlight. I put white chalk on the "T" and the "S" when I reassembled it almost a year and a half ago. I may look into it again today. Thinking about ordering the Points Saver and putting that on. Dave |
